Rear Bumper Rubber
AshM
#21 Re: Rear Bumper Rubber
Post by AshM » Tue Apr 17, 2018 9:56 pm
Pleased with a simple solution tonight that I thought I would share.
Spent some quality time on the rubber/bumper tips based on photos and views above. All good. But was left with the central section rubber only just touching the body.
I understand that the S1 rubber is a lot sharper but a well fitted wider S2 rubber can look good if tight and flat against the body. Which mine wasn't!
So used a ratchet strap attached to IRS, up and over bumper and into boot. Attaching to one of the holes on the rear of the inner boot panel. A gentle tightening of the ratchet strap squeezes the bumper towards the body so you end up with the perfect gap.
Tighten up all six bolt points and a perfect fit of rubber strip to body.
Series 2 FHC 1970
1R 20607
#22 Re: Rear Bumper Rubber
Post by PeterCrespin » Mon Jun 04, 2018 1:31 am
Simon P wrote:
Thu Apr 12, 2018 8:38 pm
Apologies - Denis Jenkinson, most famous perhaps* for looking not unlike Peter Crespin (I believe there's even a photo to that effect somewhere) :bigrin:
(*OK he's famous for rather more than that, but if Mr Crespin still has the photo I think it deserves another airing :bigrin: )
You be the judge Simon. A key difference is that the real Mille-Miglia-winning Jenks was able to enter and exit a top up OTS sans leaving generous aliquots of scalp DNA on the cant rails...
Peter Crespin
Denis Jenkinson
:shrug:
Simon P
#23 Re: Rear Bumper Rubber
Post by Simon P » Mon Jun 04, 2018 9:33 am
Still makes me smile, that one :bigrin: :bigrin: :bigrin:
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
#24 Re: Rear Bumper Rubber
Post by Heuer » Mon Feb 05, 2024 11:56 am
I was asked which was correct - cut-off or wrap around. This may help decide:
Very exact measurement from Jaguar!
