Heuer wrote: It does highlight the advantage of having a overdrive 5th gear available - a drop of about 200 RPM or 20mph increase for the same revs.
N.B. I chose 3,000 rpm because it is the sweet spot when cruising in an E-Type. With the hood down we personally find 2,800 rpm to be most comfortable.
Erm, my maths isn't that good David, but there is shurely shome mishtake in the above qote? '200rpm or 20mph' implies a gear delivering 100mph per 1000 rpm. I suspect that would be hopelessly over-geared even for the Bonneville Salt Flats :-)
My D-type uses an MOD box with a 2.88 diff,: i.e similar gearing to your OTS. I find it a little too tall even for that super light car, but I haven't had the chance to cross continents in it yet, which is when it would presumably come into its own.
My E-type uses a five speed plus 3.54 so comes out around the same numbers as a normal 4-speed plus 2.88 diff like Angus, but with good low speed (actually, first is too low). This is nice and I agree that 3000 rpm is a nice lope for the XK engine. 80mph cruise suits me fine in the UK. Any higher and you start worrying about points.
