Your point John about the porting and correct air flow is very interesting. I managed to dig out the secondary manifold....
It should scrub up nicely. It will be interesting to see what difference this makes. As you say, it may make the rear carb/cylinders run smoother. I'm thinking of draining the fuel tank and putting 98 RON in, since the manual recommends this for 9:1 compression ratio engines.
I will see what else is lying around in the garage roof and work out what my next steps are.
