Number plates
Bernie2015
Topic author - Posts: 285
#1 Number plates
Hi all,
can anyone suggest a place to get an embossed rear number plate for a series 2?
Bernie 1966 S1 OTS
#2 Re: Number plates
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
#3 Re: Number plates
Hi Bernie...just look at the similar topics below...lots of info there
Bernie2015
#4 Re: Number plates
Thanks for the quick reply, do you know what size is standard for a series 2 rear plate - Framptons not sure?
Bernie 1966 S1 OTS
#5 Re: Number plates
You can get a number of different sizes.
Mine are from Tippers Plates and are 9 and 1/2ins wide x 8 and 3/8ins high but this works for 3 numbers and 3 digits.
If you have a 3 letter, 3 number plus suffix then it will not be wide enough.
Gerry.
S2 FHC 1R20003
S2 FHC 1R20003
#6 Re: Number plates
#7 Re: Number plates
Bernie, if you look at the topic 'Series 2 Aesthetics' you'll see quite a bit of comment about changing the rear lights to those from forum member MarekH, then you can ditch the reverse lights, fit an oblong not square number plate and fit the straight S1 tailpipes. Those of us who have done it quite like the result.
viewtopic.php?f=5&t=3359
Just a thought to consider before buying your plates.
#9 Re: Number plates
Yeah.
I bought this plate from Framptons.
Bernie2015
#10 Re: Number plates
Thanks all great advice as usual can't beat this website.
Bernie 1966 S1 OTS
