Fitting seals
Bernie2015
#1 Fitting seals
Post by Bernie2015 » Tue Mar 28, 2017 1:56 pm
Hi All,
I am fitting ther rear door seals and the passenger door lower sill seals to my 1969 2+2 and am not sure which way round they go. Dont want to fix them in place before I am sure - any pointers greatly appreciated thanks Bernie (see photos)Does that look right?
Bernie 1966 S1 OTS
#2 Re: Fitting seals
Post by mgcjag » Tue Mar 28, 2017 8:03 pm
Hi Bernie...will get you a couple of photos in the morning.....
Bernie2015
#3 Re: Fitting seals
Post by Bernie2015 » Wed Mar 29, 2017 10:19 am
That would be fantastic thanks Steve
Bernie 1966 S1 OTS
#4 Re: Fitting seals
Post by mgcjag » Wed Mar 29, 2017 11:51 am
Hi Bernie....hope these help...the photo of the seal around the hatch hatch is quite ckear to see the one on the sill should be pointing up.....otherwise it will stick out under the door when its closed
Bernie2015
#5 Re: Fitting seals
Post by Bernie2015 » Wed Mar 29, 2017 5:27 pm
That's realy helpful of you many thanks just need to glue them in now!!
Bernie 1966 S1 OTS
