Guess the squeak ?????
Keith in Norfolk
#1 Guess the squeak ?????
Post by Keith in Norfolk » Tue Apr 18, 2017 6:40 pm
Recently I had an annoying budgie type squeak from the accelerator pedal.
If I put my foot on the pedal it would squeak like a budgie , if I took my foot off it would stop.
After lots of WD40 on the pedal , throttle linkages etc it would stop for a while then restart again.
I have since found the problem but I thought I would leave it to fellow E Type owners who may have had the same problem to guess what it was ?
Over to you my fellow E Type lovers. Can you guess what it was ? :shrug:
david muir
Scotland
#2 Re: Guess the squeak ?????
Post by david muir » Tue Apr 18, 2017 6:46 pm
your right knee?
1964 3.8 FHC
Keith in Norfolk
#3 Re: Guess the squeak ?????
Post by Keith in Norfolk » Tue Apr 18, 2017 6:49 pm
NOPE :bigrin:
Moeregaard
#4 Re: Guess the squeak ?????
Post by Moeregaard » Sun Apr 23, 2017 1:21 pm
WD-40 is a terrible lubricant. What happens is that the solvent carrier will quiet things down until it evaporates, leaving everything dry again. It's great stuff for drying out wet ignitions ("WD" stands for "Water Displacement"), but little else. Use a quality white grease on the moving bits and I thing you'll be pleasantly surprised.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
JagWaugh
Switzerland
#5 Re: Guess the squeak ?????
Post by JagWaugh » Sun Apr 23, 2017 1:48 pm
The bushing at the rear end of the throttle shaft? (They make a terrible squeak, but usually also stop the linkage from returning to idle consistently).
WD 40 is ok for cleaning, and not bad as a penetrant, but it's crap as a lubricant unless you can immerse the bits in a permanent bath.
White moly is good, as is Viscotene. Viscotene is my goto lube for things like window winders, throttle cranks etc. It stays where you put it, even if heated. The spray cans here come with an 80cm hose.
Keith in Norfolk
#6 Re: Guess the squeak ?????
Post by Keith in Norfolk » Mon May 08, 2017 5:59 pm
Bingo Jag Waugh :salute: yep its the little rubber bush at the end of the throttle linkage.
Mine had perished causing the linkage to drop and squeak when you put your foot down.
rossbraithwaite
#7 Re: Guess the squeak ?????
Post by rossbraithwaite » Wed May 10, 2017 12:42 pm
I've had exactly the same issue! The replacement part from SNGB is a rubber grommet that leaves considerable free play at the end of the throttle shaft. Unless there is a better part available from another supplier I was expecting to have to get something machined in nylon.
'67 S1.5 FHC, manual, maroon with black interior. Originally exported to Arizona but 'repatriated' in '89. Since converted to RHD and triple SUs.
Keith in Norfolk
#8 Re: Guess the squeak ?????
Post by Keith in Norfolk » Sat May 13, 2017 1:48 pm
Ross , I got round it by simply fitting a correct size rubber grommet from Halfords
Price £ 1.95 for two , works perfectly.
Moeregaard
#9 Re: Guess the squeak ?????
Post by Moeregaard » Sat May 13, 2017 4:13 pm
After replacing that bushing, you'll find that you have far better throttle response as well!
cactusman
#10 Re: Guess the squeak ?????
Post by cactusman » Sun May 14, 2017 7:55 am
for a light but penetrating lube use ACF 50 rather than WD40. It is brilliant....great too if wiped over aluminium and Chrome in winter to keep damp and corrosion away....
david muir
Scotland
#11 Re: Guess the squeak ?????
Post by david muir » Sun May 14, 2017 12:00 pm
not too clear as to where this bush is-just to check mine! Throttle sometimes 'lazy' to close completely once car/engine totally warmed up.
1964 3.8 FHC
JagWaugh
Switzerland
#12 Re: Guess the squeak ?????
Post by JagWaugh » Sun May 14, 2017 5:12 pm
david muir wrote:not too clear as to where this bush is-just to check mine! Throttle sometimes 'lazy' to close completely once car/engine totally warmed up.
It's on a bracket on the firewall by the wipermotor. The bushing is where the linkage changes from running across the firewall to forward to the carbs. It holds the rearmost end of the throttle rod.
Hugo
#13 Re: Guess the squeak ?????
Post by Hugo » Mon May 15, 2017 7:50 am
[quote="Moeregaard"]WD-40 is a terrible lubricant. What happens is that the solvent carrier will quiet things down until it evaporates, leaving everything dry again.
Absolutely correct. It's not a lubricant, any more than is copper grease. Many people use WD 40 as a penetrating oil, which it manifestly is not. As you say, it is a water displacing fluid - great for reviving soaked ignition systems. In the short interval before it evaporates it will have certain lubricating properties, but so does water!
