#1 Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 9:45 am
by Monkeyfinger
As I continue to work to revive the E from extended slumber, I have the above issue. Last few inches of return travel need some help from my foot. As I prepare to get up close and personal with the master cylinder, is this the most likely source of issue? I know I need to replace the old fluid - would I be wise to just get a new cylinder while I'm in there?
#2 Re: Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 11:27 am
You may need a new pedel return spring, they do snap....fitted in the housing http://www.sngbarratt.com/ProductDetail ... 7934cc&l=7
#3 Re: Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 11:54 am
by cactusman
Agree. Look at the spring first.
#4 Re: Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 2:25 pm
by Monkeyfinger
I'm liking the price but what is it like to fit? Thanks
#5 Re: Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 3:33 pm
Whats it like to fit......just another E tyoe job :bigrin: ......whilst your at it thers a similar one on the brake pedal
#6 Re: Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 4:45 pm
by Gfhug
In other words.... a long awkward job.
Not done it myself, but doesn't it require removal of items on the firewall to gain access to the rod the pedals pivot on?
#7 Re: Clutch pedal not fully returning
Posted: Tue Apr 18, 2017 5:28 pm
Hi Geoff....when i done mine i had the whole pedel box out.....cant remember now if you can get the shaft out on its own.....just a matter of getting in there and getting on with it....its not like changing a clutch :bigrin:
#8 Re: Clutch pedal not fully returning
Posted: Wed Apr 19, 2017 6:32 am
by Monkeyfinger
Great responses everyone...I will check the pedal box area and see if I can access the spring
#9 Re: Clutch pedal not fully returning
Posted: Wed Apr 19, 2017 8:46 am
Hi Monkey...whats your name......an alternative is to fit an extetnal return spring.....attached to the pedel and up under the dash area......its been done by a few others
#10 Re: Clutch pedal not fully returning
Posted: Wed Apr 19, 2017 10:20 am
by Monkeyfinger
Hi, my stage name is Richard. I read about an external return spring on another thread. I will check what the access looks like and review the options. If it is just a return spring that's broken then I'm not so worried. I need to bleed and replace the fluid also, as it's years old.
#11 Re: Clutch pedal not fully returning
Posted: Mon May 15, 2017 3:53 pm
by Hugo
Did you see my post in the tech section? I have my pedal box out as part of a conversion from LHD to RHD. Predictably, the clutch spring was broken, so I replaced it along with the brake pedal spring. Then I took it off again - it is far too stiff in my opinion. It will make the pedal heavy and felt like it was about to break when fully depressed. Didn't like it one bit. I'm going to rig something else up. If I were you I wouldn't go to all the trouble of replacing that spring, which is not a nice job in situ. Just put a light tension spring on the pedal. The brake pedal spring, incidentally, is fine. Just enough to lift the pedal back up, plus of course it doesn't travel so far. But that clutch spring - I could never live with that!
Hugo Miller Series II convertible from N Carolina changing to RHD.
