#1 Rusty fuel issues! Part 1
Posted: Thu Jun 29, 2017 10:11 pm
Hi all,
After my car introduction (viewtopic.php?f=8&t=10865) I said I would post a topic about fuel issues I have been having. Over the last few months, the car has been driven more than in the last 20 years. Recently, the revs would drop, it would feel very lumpy, then just cut out on the road.
After waiting about 30 seconds, the car would start first time and carry on as normal. Then it would start dying again. I am suspecting fuel issues.
After some research and a few helpful posts from members, I have done the following:
I took the glass fuel bowl off in the engine and cleaned it. The bottom had loads of brown crud in.
I gave this a clean and put it back on the car. Note that there was no fuel filter in the glass bowl. I have now ordered one.
This was looking ominous so the next task was the petrol tank sump drain.
I noted the odd looking fuel pump. This is one you van buy on ebay for about £15. These are sold as universal pumps. Surely this is not right. It looks nothing like the replacement pumps from Barratt. It was fitted last November during the car's overhaul at a local garage.
Anyway, I undid the small nut on the drain unit. A small amount of fuel dripped out continuously.
After draining the fuel tank as much as I could (the old fashioned way - yuck!) I undid the main nut. A bit stiff, but it turned first time. Then the gates of hell opened! The darkest brown fluid I have ever seen spewed out. I got a bowl full....
After a complete drain, the bottom of the drain sump looked like this....
And after pouring out the fuel from the bowl, I was left with this....
The fuel filter in the sump was caked ......
So, that's where I have got to so far.
No wonder the car is feeling lumpier and cutting out more when I drive it.
I think I need to remove the fuel tank from the car and clean it thoroughly.
Can anyone advise me on how best to clean it please?
I have got prices from Barratts for new glass bowl fuel filter, new sump drain washer, new fuel feed pipe filter and new fuel pump.
I am concerned that the whole system may be lined with rust deposits. The cheap fuel pump may be clogged up but I am more concerned with deposits in the carbs.
I have never touched carbs. Is there a simple method of checking the bowls.
How do I do this?
I am thinking of getting the electronic fuel pump.
Which is the best one for this car?
Anyway, time to remove the fuel tank and attempt to flush it through.
What other parts should I replace?
Perhaps fit this in-line filter (after the fuel pump or before?)
I'd like to blow all the hoses through.
Any ideas greatly received.
End of Part 1.
Catnip
2R 14343
How do I do this?
End of Part 1.
Catnip
2R 14343
