#1 Smiths clock replacement
Posted: Thu Aug 03, 2017 11:11 am
by AnD3rew
Hi there
Is there any supplier for a replacement Smiths clock the same as the original? Mine looks like it has already been modified and is broken so is suspect it may mot be possible to fix again.
#2 Re: Smiths clock replacement
Posted: Thu Aug 03, 2017 11:24 am
by Gfhug
If the face of the clock is ok, why not send it to Mike Eck in the USA, very good service, fits a modern quartz movement but clock looks like the original:
http://www.jaguarclock.com/
#3 Re: Smiths clock replacement
Posted: Thu Aug 03, 2017 12:21 pm
by AnD3rew
Thanks, I already have been in touch with him and we are still talking but he is not sure he can fix it seeing as it has probably already been modified at some point in the past.
#4 Re: Smiths clock replacement
Posted: Fri Aug 04, 2017 10:42 pm
by AnD3rew
Unfortunately Mike (great communication by the way, would have loved to give him some business) has confirmed that he can't help me.
Still need to find a replacement
#5 Re: Smiths clock replacement
Posted: Sat Aug 05, 2017 9:52 am
by johnetype
Caerbont Automotive Instruments in Swansea who are the successors to Smiths told me that they now re-manufacture a replacement for the Series 2 clock. Their web site is a bit impenetrable but the URL is:
http://www.smiths-instruments.co.uk
#6 Re: Smiths clock replacement
Posted: Sat Aug 05, 2017 12:27 pm
by AnD3rew
johnetype wrote:Caerbont Automotive Instruments in Swansea who are the successors to Smiths told me that they now re-manufacture a replacement for the Series 2 clock. Their web site is a bit impenetrable but the URL is:
Thanks for that. Can't see it on the site, but I have emailed them, will see what they come up with
#7 Re: Smiths clock replacement
Posted: Mon Aug 07, 2017 4:05 pm
by johnetype
The part number the Smiths guys wrote down for me was:
CT?2 3107-01HV
#8 Re: Smiths clock replacement
Posted: Fri Aug 11, 2017 9:27 pm
by AnD3rew
They do make one
CTE3107-01 clock - £132.80 including shipping to Australia.
Clock case is 60mm diameter, dial is white print on black background. bezel is 1/2'V' black.
Manufacturing lead-time is up to 4 weeks from order.
It looks like it will match the other dials in most respects, but it is not an exact copy in they it doesn't have the adjustment knob or screw.
I am going to keep looking for an original one for a bit but this is a backup option.
#9 Re: Smiths clock replacement
Posted: Fri Aug 11, 2017 10:47 pm
by John_Mann
They do come up from time to time on eBay, if you aren't in a hurry. I was looking for a replacement Kienzle clock for my Series 3, which I eventually found. Which, by the way I do believe that the Later Series 2 cars were also fitted with the Kienzle (dependant what was left in the parts bin as the cars were coming down the production line).
You can probably get a new Kienzle from Welsh here;
http://www.welshent.com/product_info.ph ... 83_299_303
OR
They also have the Smiths here;
http://www.welshent.com/advanced_search ... ck&x=0&y=0
Alternatively, you can try Howard instruments located in Heidelberg, here in Vic, for repairs but I don't think you'll escape for anything under $300, if indeed it can be repaired.
#10 Re: Smiths clock replacement
Posted: Sat Aug 12, 2017 3:17 am
by AnD3rew
Thanks John. That second one is the one from my previous post, but they didn't have a photo, so nice to see it in the flesh.
#11 Re: Smiths clock replacement
Posted: Sun Aug 13, 2017 10:55 am
by Steve Marshall
Andrew
You could try John Ostick
http://www.jdo1.com. He did a fine job of converting my S2 clock to quartz leaving the adjustments in place.
They are on holiday until 21st August though.
#12 Re: Smiths clock replacement
Posted: Sun Aug 13, 2017 12:52 pm
by Joerg
Hello,
four years ago I did a DIY-conversion of the broken Smiths clock of my S2 to a quartz movement. I bought a donor quartz clock, namely from an old Ford Escort (Ford part no. 95AB-15000-BB), which is numerously offered for a few Euros e.g. on ebay. The wiring of the clock can easily be seen after dismantling. I soldered the step motor, the IC, the quartz, one resistor and two capacitors out of this clock. Then I took a perfboard, cutted it to fit into the housing of the Smiths clock and to be mounted to the original mounting points. I rearranged the parts from the donor clock on that board and rewired them. To adjust the clock two added micro push buttons on the perfboard are operated by the adjustment knob and the screw of the Smiths clock. They have to be pushed now instead of turned. Finally I mounted the original hands to the step motor. The whole efforts were some pleasurable hours on a rainy Saturday and total costs of about 20 Euro. The modifications are not visible and could be completely undone.
Joerg
#13 Re: Smiths clock replacement
Posted: Sun Aug 13, 2017 2:54 pm
by Series1 Stu
Nice one Joerg.
That is true ingenuity.
It's things like this that make restoration jobs so pleasurable.
