#1 Series II Boot rattle
Posted: Mon Feb 19, 2018 4:50 pm
by vpick
I am having trouble adjusting the closing of the back hatch on my 1970 FHC. I suffer from a loud rattle at the boot, and every minuet adjustment of the "catch" yields no improvement. If I tighten the pin assembly on the door, the door won't latch. With even the smallest of adjustment, the door will latch, but the rattle is back. I have just replaced the weatherstripping with new, and no change. I have driven around the block with a piece of foam propping the door slightly open, and the noise vanishes, so I know the rattle is related to the door/latch mechanism.
Any suggestions? Are there "secondary" areas to adjust that might help?
Victor
California
#2 Re: Series II Boot rattle
Posted: Wed Feb 21, 2018 6:10 pm
by cactusman
At the risk of being had for cruelty....borrow a small child from a neighbour. Pop them in the boot and drive gently around the block and get them to listen...bet you'd have no shortage of volunteers :bigrin:
Seriously.. check he door is not is not misaligned and actually impacting the bodywork rather than the door rubber...might be the stay arm...maybe a bit of trim loose...could be almost anything..
