#1 Wet plug fouling
Posted: Fri Mar 09, 2018 10:57 pm
by AnD3rew
Hi there, I am getting oily wet fouling on the 3rd cylinder from the front (technically not sure what cylinder number that is) I assume it’s probably either a head gasket or a valve guide.
Any advice on which it’s most likely to be or if there is another option I have missed?
#2 Re: Wet plug fouling
Posted: Sat Mar 10, 2018 7:11 am
by Nickleback
Have you tried moving the plug to another cylinder to see if the problem moves with it, also you could do the same with the HT lead & cap to check first ?
#3 Re: Wet plug fouling
Posted: Sat Mar 10, 2018 11:35 am
by AnD3rew
Have replaced the plug several times. All new 123 distributor, new leads, new coil.
#4 Re: Wet plug fouling
Posted: Sat Mar 10, 2018 12:46 pm
by Paul71a
Can’t help with the problem but can help on your cylinder numbering!
That’s cylinder 4 They’re numbered from the bulkhead to the front of the car.
I’m sure a techie bod will be along in a minutewith ideas on the issue......
