Wipers
TomD
#1 Wipers
Post by TomD » Mon Aug 13, 2018 5:12 pm
My wipers only work on one speed. Could that be the switch, or is it likely to be something else.
Tom
johnetype
#2 Re: Wipers
Post by johnetype » Mon Aug 13, 2018 5:27 pm
Please be more specific. Only slow speed or only fast speed? Same speed whichever position the wiper switch is in? Engine running or engine off?
1969 Series 2 FHC
TomD
#3 Re: Wipers
Post by TomD » Mon Aug 13, 2018 8:12 pm
Only slow speed. Stops on fast speed. Engine running or full ignition on.
mach2andy
#4 Re: Wipers
Post by mach2andy » Tue Aug 14, 2018 8:40 am
Hi Tom
I've just been testing my wiper motor on the bench, and I found that it only worked on on slow speed. By fiddling around, I found that it was the switch that was at fault. The new switch was less than £20 so maybe that would be the place to start?
ATB
Andy
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
#5 Re: Wipers
Post by malcolm » Tue Aug 14, 2018 9:42 am
I had exactly the same problem. It was the switch. After cleaning and repeated on/offs, it started working again, and has ever since.
johnetype
#6 Re: Wipers
Post by johnetype » Tue Aug 14, 2018 10:22 am
If you have a multimeter connect it to the yellow/light green wire at the back of the wiper switch and earth.
If you get 12 volts or so when you select fast speed on the wiper switch then the problem lies with the motor or the wiring to it. If you don't see 12 volts, replace the switch as Andy suggests.
1969 Series 2 FHC
TomD
#7 Re: Wipers
Post by TomD » Tue Aug 14, 2018 1:44 pm
Thanks for the suggestions - I will look this evening
