#1 Steering rack mounting
Posted: Wed Jul 11, 2018 12:06 pm
The pictures show how my passenger side rack mounting was attached when I dismantled the vehicle, but I don't think this was right? You will see that there is a spacer fitted behind the head of the long top bolt, but I think that the spacer arrangement should only be fitted on the drivers side. This long top bolt that has the spacer was just that. A 3" long bolt with 2" of plain portion. I think this should be a fully threaded screw with a plain nut between the 2 plates that make up the rack mounting as in the shorter bottom bolt shown in the bottom picture?
Thanks in advance
Thanks in advance
