#1 Front Caliper seals
Posted: Tue Dec 04, 2018 11:59 am
Hi guys,
Wonder if anyone has come across this problem before...
I am rebuilding my front calipers and i have bought a new seal kit.
A couple of weeks ago I rebuilt the N/S caliper and it went together OK, bit awkward getting the outer piston covers on, but once I understood the process it went OK and the caliper is rebuilt.
However I have now come to do the O/S (by the way I don't think O/S - N/S has any bearing on my problem) the problem is the seals are a very loose fit inside the bore in both the large piston bore and both the small piston bores.
They protrude from the groove to the extent that fitting the piston is nigh on impossible.
I do not recall having this issue with the N/S caliper.
Has anyone encountered anything like this before? I have tried gently stretching the seals, but to no avail.
I have also read that rubber reacts different to most other materials in that it expands when cold, so I am now trying to keep the caliper in a warm place and seals in the fridge to try again.
Both sets of seals came from same packet so I think unlikely the seals are incorrect as the other seals for N/S caliper fit well.
Anyone any ideas?
Many thanks
Peter
Anyone any ideas?
Many thanks
Peter
