#1 Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 1:44 pm
by PAN4213
Hello all,
Will be starting the refurb of my series 2 soon.
Any adaptations I need to do for the car to run on unleaded?
thanks
Series 2.1969 2+2. US import.
Merc R107 300sl. 1989
#2 Re: Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 1:59 pm
by malcolm
As far as I know, none. The valve seats are already hardened
#3 Re: Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 4:02 pm
by 64etype
8:1 pistons?
#4 Re: Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 4:17 pm
by malcolm
Don't think it matters whether it's 8:1 or 9:1, valve seats the same. You might want to wait and check with others on here who know more than I, but i'm reasonably confident that's right.
#5 Re: Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 7:16 pm
by Mark Gordon
You're right, Malcolm. All E Types run just fine on unleaded. The only problem with modern fuels that some have experienced is due to EtOH in some of the blends: water vapor absorption leading to tank rusting and eating away at rubber components in the fuel lines. I've been running E10 (10% ethanol) for ten years without any problems.
#6 Re: Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 7:23 pm
by 64etype
I was thinking about pinking due to generally lower octane ratings with unleaded.
#7 Re: Adapatations to run on unleaded.
Posted: Tue Dec 04, 2018 11:34 pm
64etype wrote: ↑
Might be a problem if you have higher compression in your motor. I use 95 RON with no problems. My engines have around 160psi compression.
I had no end of trouble with a car with compression around 185/190psi and finally ended up fixing the problem by fitting a very thick head gasket and lowering the compression.
In general it is sensible to use 8:1 pistons if you rebuild, to compensate for skimming of the head and block.
As mentioned above the seats are already fine for ULP use.
#8 Re: Adapatations to run on unleaded.
Posted: Wed Dec 05, 2018 12:44 am
by AussieEtype
64etype wrote: ↑
8:1 pistons?
What do the pistons (compression ratio) have to do with running on unleaded or not - octane level of the fuel yes but not whether it is unleaded or not.
Sorry saw this later
64etype wrote: ↑
You just buy the unleaded fuel that has the octane rating to suit your engine. 98 Octane unleaded works fine in engines that required the old UK 5 Star.
cheers
garry
#9 Re: Adapatations to run on unleaded.
Posted: Wed Dec 05, 2018 9:19 am
by malcolm
Even octane rating doesn't seem that sensitive. I'm on 9:1 pistons. I buy the highest Octane I can, normally 97, but often 99 (Shell or Tesco) However, touring the backwaters of France and Spain I often had to settle for 95 and it ran fine.
#10 Re: Adapatations to run on unleaded.
Posted: Wed Dec 05, 2018 1:51 pm
by PAN4213
thank you loads everyone.
Rgds
Series 2. 2+2 1969 US import.
Merc R107 300SL
