#1 New Left Window Regulator Binding.
Posted: Tue Jun 18, 2019 3:35 pm
by FHCINSC
The old one had badly stripped out gears. This is a brand new one. It installs fine but seems to bind up on itself and bends as you lower the window. Appreciate any advice.
#2 Re: New Left Window Regulator Binding.
Posted: Sun Jun 23, 2019 10:59 pm
by Jeremy
You just have to examine exactly what is catching/binding with what, and do a bit of careful bending to get the offending bits out of each other's path. When I was trying to get my (orginal) mechanisms to work within the (new) doors, I concluded that it's a mechanism that isn't particularly stiff (so everything flexes under load) or constructed to particularly tight tolerances - yet it's required to operate within a tightly constrained space. Like trying to push a banana on the end of a fishing rod through a letter box...
#3 Re: New Left Window Regulator Binding.
Posted: Tue Jun 25, 2019 12:32 am
by FHCINSC
Thank you. I have requested a new replacement regulator from the vendor. No amount of fidget work was going to help.
Anthony
#4 Re: New Left Window Regulator Binding.
Posted: Tue Jul 09, 2019 1:59 pm
by FHCINSC
The vendor sent a replacement regulator and it works much better. Thanks all.
