Speedo Cable
#1 Speedo Cable
How should the speedo cable be secured along it's route?
Thanks in advance.
Andy
Thanks in advance.
Andy
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
1970 S2 FHC
#2 Re: Speedo Cable
Mine isn’t secured anywhere. There’s so much else going in under the bonnet that the cable just rests against various other things - frame rails, vacuum pipes, etc. I think the essential thing is to ensure the cable follows the smoothest possible curve from the bulkhead to the gearbox. The PO had mine going all over the shop in all directions, with the result that the inner wore the outer and the speedo needle jumped all over the place.
Jeff Cecil
#3 Re: Speedo Cable
There is a metal clamp on the top left bell housing bolt that secures the speedo cable.
#4 Re: Speedo Cable
Unlikely , I'm afraid Jeff, on a RHD carJeff Cecil wrote: ↑Wed Jul 24, 2019 8:56 pmThere is a metal clamp on the top left bell housing bolt that secures the speedo cable.
#5 Re: Speedo Cable
The clip supports the speedometer cable where it runs over the geabox. The brackets are different for LHD and RHD; part #C17410 for RHD and available from Richard Smith.
Jeff Cecil
#6 Re: Speedo Cable
Oh, I forgot, you guys drive from the wrong side.christopher storey wrote: ↑Thu Jul 25, 2019 10:06 amUnlikely , I'm afraid Jeff, on a RHD carJeff Cecil wrote: ↑Wed Jul 24, 2019 8:56 pmThere is a metal clamp on the top left bell housing bolt that secures the speedo cable.
#7 Re: Speedo Cable
This is the top clip:
The part number of the gearbox clip for LHD cars is C18128. SNGB sell it. it bolts onto the top front of the gearbox housing. This is a LHD car:
Incidentally the original speedo cables were a beige/grey colour rather than the black that is currently available.
#8 Re: Speedo Cable
Thanks everyone. I think I might have seen this clip in one of my many boxes of bits. My engine and gearbox are now fully installed, but I'm thinking that the bell housing [ sorry Jeff clutch housing ] bolt may be accessible from inside the car. My cable is grey so maybe an original item?
Andy
Andy
Andy
1970 S2 FHC
1970 S2 FHC
Jeff Cecil
#9 Re: Speedo Cable
You're correct Andy, the "bell" housing is on your Corvette.mach2andy wrote: ↑Sat Jul 27, 2019 8:31 amThanks everyone. I think I might have seen this clip in one of my many boxes of bits. My engine and gearbox are now fully installed, but I'm thinking that the bell housing [ sorry Jeff clutch housing ] bolt may be accessible from inside the car. My cable is grey so maybe an original item?
Andy
#10 Re: Speedo Cable
The parts book for the series 2 has listed the clip (c17410) and a ufs131/4r , nut and shakeproof washer . I have seen in previous postings that this clip is fixed to the rear engine mount tower. There are two holes in the lower portion of the tower.
Regards ,
Greg
Regards ,
Greg
#11 Re: Speedo Cable
HI Jeff
Yes, my car is RHD. I found lots of odd clips in one of my many boxes of bits, but not the right one. I'm assuming it's secured just to stop it clattering around and chaffing on something?
Looks like I'll be making something up.
Andy
Andy
Andy
1970 S2 FHC
1970 S2 FHC
