#1 Wiper & washer earth connection
Posted: Mon Oct 14, 2019 7:44 pm
Hi All,
So 200 miles after my engine rebuild etc. we went out on a Jaguar drive out day yesterday and it started raining (first time out in the rain since the rebuild) and...
Switched on the wipers to slow and they didn't work, tried fast... same problem. At first I thought fuse but the fuses (6 &7) are shared with other things that worked fine. Then i thought maybe a duff switch but before pulling it apart I thought to try the washers and they didn't work either.
Luckily I had RainX'd the windscreen and the rain stopped shortly after reaching my destination so at least I could see where I was going.
This evening I have spent a little time chasing the wiring with a multimeter and have worked out that they both share the same earth feed and sure enough, a temporary earth fixed the issue.
Does anybody know where the earthing point is for these two items? I assume I have either disturbed it during the engine out/in process or left it off by mistake.
Brian
Brian
