RHD wiper arms
grimes6
#1 RHD wiper arms
Post by grimes6 » Fri Aug 30, 2019 6:25 am
I have just looked up the Lucas part number for the RHD wiper arms on the Series 2 and this is 54715802. If you search on ebay under this part number it will bring up wiper arms which fit a Scammel Dump Truck RHD. I have also checked the original Lucas parts book and it also lists this part number for the series 2 E type. If you are looking for the "hard to get" RHD wiper arms this maybe an opportunity . I have no connection with the ebay seller. Maybe worth checking with the seller if this number for the item is correct.
Greg
MaxP00
#2 Re: RHD wiper arms
Post by MaxP00 » Mon Oct 21, 2019 3:52 pm
I have just looked up the Lucas part number for the RHD wiper arms on the Series 2 and this is 54715802. If you search on ebay under this part number it will bring up wiper arms which fit a Scammel Dump Truck RHD. I have also checked the original Lucas publix passprt parts book and it also lists this part number for the series filehorse 2 E type. If you are looking for the "hard to get" RHD wiper arms this maybe an opportunity . I have no connection with the ebay seller. Maybe worth checking with the seller if this number for the item is correct.
Greg
Yea absolutely. Check with the seller. The one I bought I got the number right.
Lucas items often get duplicated so its always advisable to cross check the number.
JerryL770
#3 Re: RHD wiper arms
Post by JerryL770 » Tue Oct 22, 2019 11:56 am
SNGB have uprated arms available which keep the blades on the screen and have a more secure fitting on the splines.
Jerome Lunt
