mach2andy
Post
by mach2andy » Wed Oct 23, 2019 6:52 pm
Does anybody recognise this clip?
Thanks in advance.
Andy
1970 S2 FHC
1965 SB Corvette Ragtop
Post
by christopher storey » Thu Oct 24, 2019 7:27 am
It is similar to the clip which secures the downlink from the door handle to the door latches
Post
by abowie » Thu Oct 24, 2019 8:25 am
I'm betting not E Type.
tim wood
Post
by tim wood » Thu Oct 24, 2019 9:11 am
And I’m with you on that Andrew.
Is it made of plastic?
Robsan
Post
by Robsan » Thu Oct 24, 2019 11:26 am
I dont think etype either [unless series 3]
It looks like a sliding and locating clip from Saab door handle....................... you locate the door handle from outside the car..................... kind of looping it in, then the clip slide in from behind and latches the handle in place
Not saying its Saab , but looks like a part doing the duty as described
mach2andy
Post
by mach2andy » Thu Oct 24, 2019 5:21 pm
I had to disassemble my wiper motor to get the armature rewound and very assiduously kept all of the bits and pieces involved in a box. The armature came back the other day, and after I'd put everything back together again, this clip was left over. Hence the post. I'm thinking that maybe this [metal] clip was tucked away inside the box before I put all my wiper bits in it?
Thanks for your input boys.
Andy
Andy
1970 S2 FHC
tim wood
Post
by tim wood » Thu Oct 24, 2019 7:33 pm
If you have a parts book a search of the wiper motor section may reveal something ?
288gto
Post
by 288gto » Thu Oct 24, 2019 9:02 pm
Picture from Chris Vine’s blog if that’s any help?
I does look vaguely similar to the clip on the motor arm.....
JerryL770
Post
by JerryL770 » Fri Oct 25, 2019 7:08 am
It's curious how your 1st picture is with postimages.org and will not display when I click on it while the second is with postimg.cc and does display.
I have found that if you right click on the former picture and select "copy image location" and paste that into the address bar of a new tab, bingo, it shows.
Jerome Lunt
2008 MX-5 NC PRHT - now gone
288gto
Post
by 288gto » Sat Oct 26, 2019 8:09 am
mach2andy wrote: ↑Wed Oct 23, 2019 6:52 pm
Thanks in advance.
Put us out of our misery when you do find out Andy.
tonyabacus
Post
by tonyabacus » Sun Nov 03, 2019 8:35 pm
Andy
It looks as if the centre of the clip is square suggesting it is located on a square shaft rather than a round shaft, whether that is a reminder of another job that the clip belongs to, but looking in the parts book at the wiper assembly, this type of clip does not stand out anywhere.
Tony
ps Did you race in the SR> series?
mach2andy
Post
by mach2andy » Mon Nov 04, 2019 2:10 pm
Hi Tony
Yes I'd come to the conclusion that it secured something on a square shaft. But I'm still none the wiser as to from whence it came. It's definitely not wiper related that's for sure. So I'm thinking that it was tucked away in the box before I put the wiper bits in.
Wrong Andy by the way. The only place I race is down to the Nut & Bolt store.
Andy
Andy
1970 S2 FHC
- Moderator
Post
by 1954Etype » Mon Nov 04, 2019 4:17 pm
Definitely secures the wiper link.
