ArtH. wrote: ↑Tue Jan 14, 2020 7:29 am
I will appriciate very much if somebody can tell me how to fix that rubber which is inside. I took it apart and I will put it back together but just for now I do not have idea how to replease that rubber membrane.
Believe me, Artur, if you have dismantled that servo in a way that reassembly is even possible, you know more than 99% of us, including me. If a flat round sheet of rubberised material is perished or torn, find a similar piece of rubber or plastic sheet and use the old one as a pattern. If it works by moving a rod riveted to the centre, use a long thin threaded rod with washers and nuts to clamp it. If you opened it by carefully unfolding the edge, bend it carefully back with glue or sealant to help it stay air tight. It would be great to see pictures and you will be the new king of diaphragm repair*.
Hail King Arthur of the Round Servo
*If you get an email from a clinic asking you to repair their diaphragms, say no.
