I’m struggling with my renovation, trying to complete every missing part and there are a lot of them. Right now I just made a total overhaul on my triple SU’s and noticed that there are some questions left regarding this.
Should my LHD -69 with original triple SU’s have insulator blocks between carbs and intake manifold since this could imo affekt the alignment of the throttle linkage?
Should there be 3 Y-shaped bracket for the throttle return springs or should the rear one be the triangle shaped with a shorter spring?
Insulator between carb gaskets
#2 Re: Insulator between carb gaskets
Hi Peter,
Yes there should be insulation blocks (C17413); gasket each side .
https://www.sngbarratt.com/uk/#!/Englis ... 93f502031c
And two Y brackets and one triangle piece.
https://www.sngbarratt.com/uk/#!/Englis ... ING%20RODS
#3 Re: Insulator between carb gaskets
Thanks, now I know what to order
//Peter
1969 Serie 2 OTS
1969 Serie 2 OTS
