Gearbox Stud part C21336
japomero
#1 Gearbox Stud part C21336
Post by japomero » Wed Mar 04, 2020 1:12 am
When I disassembled the rear engine mount from the tail of the gear box on my '71 FHC it certainly was not to standard.
Working with the assembly drawings from SNGB I have ordered or machined all the parts to put it right.
The question I have regards the Gearbox Stud (part C21336). There is a cross drilled hole in the end but no indication if there is supposed to be a pin or bolt or what when it is assembled.
Any chance someone could provide a photo of how the assembly is finished in the car?
Jim
#2 Re: Gearbox Stud part C21336
Post by mgcjag » Wed Mar 04, 2020 8:31 am
Hi Jim.....the cross drilled hole is to fit a pin just as an assembly aid....it should not be left in place once the gearb/mount is fitted to the car....Steve
japomero
#3 Re: Gearbox Stud part C21336
Post by japomero » Wed Mar 04, 2020 2:03 pm
Thanks Steve
#4 Re: Gearbox Stud part C21336
Post by PeterCrespin » Fri Mar 06, 2020 12:38 am
I think the pin may have been a shipping aid to stop the engine/gearbox moving around too much in transit and to be removed during pre-delivery inspection. On later IRS lower shock mounts they added a bracket to chain or strap the cars to the deck, but that was just the XJ and XJS I think.
#5 Re: Gearbox Stud part C21336
Post by MarekH » Sat Mar 07, 2020 7:50 am
The US bound etypes also had them in 1974 Pete.
I left them on my car, even though they have no function now.
