#1 Series 2 - Reaction Tie Plate & Engine Mountings
Posted: Mon Mar 09, 2020 9:49 pm
by JC
As part of 'taking stuff off' to get ready to lift the body off the engine, I'm (hopefully) left with just the reaction tie plate and the engine mountings - both look scary!!
Reaction Tie Plate - I've found this thread on the forum. Can someone confirm that the advice offered is sound, please?
viewtopic.php?t=7656
Engine Mountings - I see three - Is there a recommended approach for disconnecting these. I guess there should be a relevant thread on the forum, but I couldn't find it!!
#2 Re: Series 2 - Reaction Tie Plate & Engine Mountings
Posted: Mon Mar 09, 2020 11:14 pm
Hi ..you need to read all posts in the link...post 2 is a better way to go...note that the key poing is to ensure that all the tension is released from the torsion bars by releasing the front wishbones...i would advise that you actually read the service manual so you have a clear understanding of what you are doing....the same for the engine mounts....the weight of the engine must be taken up befor releasing then...the service manual is your friend, it fully details engine removal....Steve....edit..PM sent
#3 Re: Series 2 - Reaction Tie Plate & Engine Mountings
Posted: Tue Mar 10, 2020 1:55 am
by keithmac
After Carefully reviewing all the info and the shop manual, you have nothing to fear but fear itself ! ( apologies to FDR ) I went through the exact same concerns when doing mine for the first time.
Cheers !
#4 Re: Series 2 - Reaction Tie Plate & Engine Mountings
Posted: Tue Mar 17, 2020 6:59 pm
by JC
Thanks for your help. The reaction plate is now off!!
Next, the engine mounts
