NARDI Steering wheel
GDE
#1 NARDI Steering wheel
Post by GDE » Mon Apr 27, 2020 9:04 am
Hello everybody,
I have a nardi steering wheel that I would eventually like to install on my 4.2 S2 because I find it more pleasant and I don't have the original steering wheel. the motolita and nardi hubs are different, someone has already managed to put a nardi hub and nardi steering wheel on the E-type ?
do you have product references ?
Thank you in advance,
Greg
GDE
1970 FHC 4.2 serie 2
#2 Re: NARDI Steering wheel
Post by mgcjag » Mon Apr 27, 2020 9:42 am
Hi Greg...I havent fitted a Nardi but have played around with different wheel bosses.....do you have the original style aluminium E type boss......you could diy an adaptor (adapror below)to fit between this and your Nardi........note the splines on you upper shaft should be 7/8in 48 splines.....this adaptor on ebay could work..if has the correct splines and an adaptor to fit Nardi....Steve https://www.ebay.co.uk/itm/Steering-Whe ... Swo0JWLZYu
https://www.ebay.co.uk/itm/Black-CAR-St ... 0667.m2042
donpablito2016
Czech Republic
#3 Re: NARDI Steering wheel
Post by donpablito2016 » Sun May 03, 2020 1:24 pm
Hi Greg,
yes, I have fitted smaller diameter nardi steering wheel with this hub https://www.ebay.de/itm/Nabe-Lenkradnab ... SwrklVHTdf
Looks quite good in black. Nardi wheel photo:
best
Pavel
e type series 1.5 2+2
