where to get the small seals between 2 brake caliper halves
rolando38
#1 where to get the small seals between 2 brake caliper halves
Post by rolando38 » Thu Sep 03, 2015 7:51 pm
here is what they look like, they are not included in the usual brake seal kits, as one is not supposed to separate the 2 halves, but then how the hell can you overhaul them ??
see top right; one is damaged
Post by mgcjag » Thu Sep 03, 2015 9:38 pm
Hi Roland....done the same as you and separated my calipers....cleaned them up and had them zinc plated but not the inside of the bores, then refaced the mating surfaces...hunted around to find some flat o rings to replace the seals.....just found them in a local hydraulic supplies shop....The type that supplies pipes etc to tractors/ farm machinery. ..just make sure that you locktite the bolts when you rejoin the two half's. .... Steve
rolando38
Post by rolando38 » Fri Sep 04, 2015 6:37 am
great advice thanks !
2+2 1970
rolando38
Post by rolando38 » Sun Sep 06, 2015 10:57 am
just for later reference, the dimensions of the seal are:
outer Diameter 0.5 " (12.6 mm)
inner diameter (hole) : 0.3" (7.5 mm)
thickness: 0.06" (1.63 mm)
2+2 1970
JagWaugh
Switzerland
Post by JagWaugh » Sun Sep 06, 2015 11:41 am
Don't forget that they are square section. I got mine from John Farrel iirc, from whom I ordered my stainless pistons.
Andrew
rolando38
Post by rolando38 » Sun Sep 06, 2015 6:34 pm
thanks
thery don't appear on their website
https://etypeparts.myshopify.com/collections/brakes
I also found them at Terry's jag, but I would prefer a UK or France provider for shorter delivery time
http://www.terrysjag.com/mm5/merchant.mvc?
reference is 67320782X
2+2 1970
JagWaugh
Switzerland
Post by JagWaugh » Sun Sep 06, 2015 6:47 pm
Try AP racing, or any stockist of their parts. These are common to a huge number of lockheed calipers, referred to variously as "Bridge, Channel, Cross Feed, or Cross Over Seals"
Should be pretty easy to find in the uk.
JagWaugh
Switzerland
Post by JagWaugh » Sun Sep 06, 2015 6:55 pm
And when you do find them, if they are less than 1GBP each, get 12 or so... you never know.
You will also find it a LOT easier to fit the pistons, seals and dust boots before you reassemble the halves.
Andrew
rolando38
Post by rolando38 » Mon Sep 07, 2015 5:08 am
Yes Andrew that's for sure
I already replaced the other seals and pistons (apart from the faulty one still waiting for delivery) and that's child play once caliper is in 2 halves
2+2 1970
jivili
Post by jivili » Thu Sep 10, 2015 9:21 am
I got mine for a series 3 from this company
http://www.powertrackbrakes.co.uk
rolando38
Post by rolando38 » Fri Sep 11, 2015 7:38 pm
thanks, I read your post too late, and got mine from
http://www.etient-freins.com/
not cheap, but fast
2+2 1970
UK Muppet
#12 Re: where to get the small seals between 2 brake caliper halves
Post by UK Muppet » Wed Jan 27, 2021 2:50 pm
I have been searching for these bridge seals for the past week or so and have spent a number of hours looking at numerous websites. I found they seem to be readily available in the US and only cost cents which is what I would expect. However finding them in the UK is not so easy. Anyway yesterday I had to drop some parts off at a plating shop and I realised I was not far from a company that deals in AP Racing parts among others and so I called in on them. When I mentioned Girling calipers the reply was " ooh no, we only deal with AP and your not supposed to split calipers so we would not be able to get them anyway". They then suggested I try Brakes International which was a couple of miles away. Better result, they knew exactly what they were and the part number but had no stock but would order them from Denmark! As I was leaving one of the guys said try Bigg Red in Worcester, they should have them. So got in the car found the phone number and called them. I was dealt with very efficiently and politely and asked how many I wanted, I said I needed 4, gave card details and address and the guy said he would post them. To my surprise a box appeared at lunch time today containing the 4 seals. A bit more expensive than the US but less than some suppliers I found by quite a margin and they did not charge for postage so I was very pleased. :bouncyyellow:
Tony
Tony
69 Series 2 2+2 auto
Joes66
#13 Re: where to get the small seals between 2 brake caliper halves
Post by Joes66 » Wed Jan 27, 2021 6:48 pm
I recently re built all my calipers
And they came in the seal kits
I don't know why they are not in yours
Very odd
This is the company I got my kits from
E bay item number 402040150933
If you look you can see them in the picture
They do kits for all models
They are very helpful
Joe
1969 series 2 2+2
#14 Re: where to get the small seals between 2 brake caliper halves
Post by mgcjag » Wed Jan 27, 2021 7:05 pm
Hi Joe....I just edited out the link you posted......it took me to a scam prize winning site......please recheck and preview befor posting. ...thanks...Steve
Joes66
#15 Re: where to get the small seals between 2 brake caliper halves
Post by Joes66 » Wed Jan 27, 2021 8:48 pm
Thats odd
Sorry mate
I took the link directly from my e bay
Strange
Joe
1969 series 2 2+2
johnetype
#16 Re: where to get the small seals between 2 brake caliper halves
Post by johnetype » Thu Jan 28, 2021 9:56 am
:yeahthat: +1 for Bigg Red
but Classicar Automotive in Macclesfield do an excellent job of rebuilding your callipers for you, inc. re-plating and stainless steel pistons for around the same as you buying the parts and doing it yourself and you get your own callipers back.
1969 Series 2 FHC
Pex
Sweden
#17 Re: where to get the small seals between 2 brake caliper halves
Post by Pex » Tue Feb 02, 2021 7:08 pm
Same Girling calipers as on à Volvo P1800, I order everything from this Swedish firm much cheaper than for a jaguar.
https://vp-autoparts.se/sv/artiklar/pac ... -fram.html
//Peter
1969 Serie 2 OTS
angelw
#18 Re: where to get the small seals between 2 brake caliper halves
Post by angelw » Wed Feb 03, 2021 11:18 am
@ UK Muppet
Hello Tony,
Searching the Biggred website for Part No. BRS222106 and all derivatives down to 222106 results in:
"No products were found that matched your criteria"
UK Muppet
#19 Re: where to get the small seals between 2 brake caliper halves
Post by UK Muppet » Wed Feb 03, 2021 2:16 pm
Hi Bill, I made a search myself with the same results as you, so no answer other than the website is not brilliant. I found it a little troublesome to use.
I can only say calling them did the trick, I just said I wanted bridge seals for Girling calipers and they asked what the size was due to there being 2 sizes. I got them the next day with the part number shown on the bag and invoice. I didn't make it up.
Maybe its something to do with the scare tactic of telling you that you must not split calipers. :scratchheadyellow:
As for getting calipers rebuilt for about the same as buying the parts as Johnetype suggested, I very much doubt that could be achieved, if it was possible they must rebuild them for nothing.
It cost me 70 quid to rebuild my rear calipers, including plating, 4 new pistons (standard not st/st) and new seals and I had the pleasure of doing it myself which helped relieve the lockdown boredom.
Tony
#20 Re: where to get the small seals between 2 brake caliper halves
Post by abowie » Wed Feb 03, 2021 11:14 pm
The square profile o rings are called "channel seals".
They are a standard sized generic item. I took a sample into my local brake place and they had them on the shelf.
