#1 fumes from dipstick hole
Posted: Wed Feb 03, 2021 2:36 pm
by Pianoman
As the title says I have fumes coming from the dipstick hole. Is there a seal missing or what could be the problem? thanks
#2 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 3:13 pm
Yes a seal on tne dipstick....SNGB list them....Steve
#3 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 3:53 pm
by Pianoman
phewwww..... thanks a million
#4 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 5:34 pm
by MarekH
Does this car have anything that passes for a PCV system? Would it not be a good idea for the crankcase fumes be drawn into the carburettors? If not, then the seals will simply be put under pressure until an oil leak is created as the fumes condense and are pumped out elsewhere.
#5 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 6:13 pm
by Pianoman
I dont see the seal on the SNG site just the Dipstick.... for 93 quid ????
I dont know about the PCV system Marek
#6 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 6:18 pm
by christopher storey
Donal and Marek : yes, the 6 cylinder cars have ( or should have ) a collection device at the front of the top dome at the front of the engine, which is connected by flexible hose , usually of the corrugated metallised cardboard type , to a port on the inner face of the trifurcated backplate which connects the carburetters to the air filter plenum chamber . If crankcase pressure is building then it seems likely that this system is clogged, which does happen particularly if the engine is only run for short periods
#7 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 7:17 pm
by Pianoman
Thanks Christopher, that would make perfect sense as the car is only started and not driven during this winter. How can I approach a fix to this?
#8 Re: fumes from dipstick hole
Posted: Wed Feb 03, 2021 7:24 pm
Remove round cover on front of the head and clean the filter gauze.....Steve
