Series 2 Heavy brake pedal pressure
#1 Series 2 Heavy brake pedal pressure
I changed the master & servo cylinders 3 years ago and the brakes were fine ; of late the pedal pressure is really hard almost as if the servo is not working. The tank is holding pressure and you can hear presuure being released when operating the brakes.Any ideas before I start the expensive job of replacing servo & brake master cylinders again?
I think your problem is already being dealt with here: http://etypeuk.com/forum/viewtopic.php?t=1716
S1 OTS OSB; S1 FHC ODB
