#1 Difficulty starting
Posted: Sun Aug 29, 2010 9:07 pm
by pip007
(Car is S2 with twin Strombergs). From cold, it takes anywhere from 10-24 attempts before engine will fire, thereafter during same day it will start first try. I?ve replaced coil, all HT leads and plug caps, contact points, distributor cap, and spark plugs. Made no difference. I?m using choke to start (not using choke does not improve matters). Carbs were recently serviced and set up by E-type experts. Any suggestions?
Posted: Mon Aug 30, 2010 10:31 am
by daverawle
You could try leaving the fuel pump run for a couple of minutes to see if that helps - it may be losing it's 'prime'
Posted: Mon Aug 30, 2010 12:33 pm
by pip007
Thanks Dave, I'll try that.
