#1 FHC rear hatch support bracket
Posted: Tue May 25, 2021 7:28 am
by Quattrofrank
Does anyone have a picture showing the three holes in the body to attach the bracket /prop that holds the rear hatch open on a fhc?
Forgot to drill new holes in body when the car had the rear panels and floor changed and the replacement panel does not have the holes pre drilled
#2 Re: FHC rear hatch support bracket
Posted: Thu Jun 10, 2021 2:27 pm
by JerryL770
Have you done it yet?
What's wrong with just using the support bracket as a template? With the other end attached to the door, find the place it sits properly and mark the holes.
#3 Re: FHC rear hatch support bracket
Posted: Fri Jun 18, 2021 11:15 am
by Quattrofrank
Have not done it yet.
I suppose that will work, but the support is angled and I guess there is a sweet spot were it should be attached to the body. So that the hatch doesnt open too much or too little
#4 Re: FHC rear hatch support bracket
Posted: Fri Jun 18, 2021 11:47 am
by JerryL770
Does this help?
The mount bracket is 7 inch from the centre of the boot hatch.
Jerry
