#1 OTS Interior Light Wiring Missing
Posted: Wed Jun 09, 2021 7:30 pm
by TheMadBadger
Good afternoon,
I finally got around to checking why the interior light doesn’t work on my series 2 convertible, besides the bulb being missing. The switch has power in and out, with the correct color wires, so I pulled the interior lamp housing out to check it and there is no wiring to it. Can anyone tell me where the wiring for this light would be routed so I can start looking around for it? Would it come in from the trunk side, or under the interior trim inside the cockpit?
I like everything to work on my car so if all I need is to find the lamp wiring and run it properly I will. Or maybe run a new one if it comes down to it, but so far the wiring on the car has been all correct and not bodged.
The car is a left hand drive but I don’t think it would matter for this component.
#2 Re: OTS Interior Light Wiring Missing
Posted: Thu Jun 10, 2021 12:47 am
by 288gto
Hi Mark,
I'm assuming you mean the light on the rear bulkhead. From memory the wiring is in the boot/trunk and comes off the loom from the left hand side where the hinge mounts.
#3 Re: OTS Interior Light Wiring Missing
Posted: Thu Jun 10, 2021 3:14 am
by TheMadBadger
Yes Simon, your assumption is correct. The routing you mention makes the most sense. The harness is visible where it comes into the trunk and along the side but I can’t see a lead coming off it to the bulkhead lamp. I will take a closer look.
Thanks you
#4 Re: OTS Interior Light Wiring Missing
Posted: Thu Jun 10, 2021 7:15 pm
by TheMadBadger
Good afternoon,
I did some digging into the left side of the trunk compartment; removed trim panels, etc. I found the lead to the interior lamp but it exited the harness very far back in the car near the gas tank filler -too far to ever reach the lamp. I cut into the harness wrap up where the lamp wire should have exited and pulled the wire out there, then ran it to the lamp. The lamp works perfectly now. I taped up the harness wrap, reinstalled the trunk trim and job done and dusted.
Thanks for the help
