#1 Headlamp drain holes in bonnet underpanel
Posted: Sat Jul 17, 2021 1:55 pm
by Tonyminett
Hi, can some kind person send me a photo showing the position of the headlamp drain holes in the bonnet underpanel? Thanks a million in advance. Tony.minett@ gmail.com
#2 Re: Headlamp drain holes in bonnet underpanel
Posted: Sat Jul 17, 2021 4:03 pm
by Gfhug
Tony, welcome to the forum. Mine came out through the 1 1/2 inch holes in the underpanel just in front of the cross member with a P clip to hold them in place. Sorry, no photo to hand. And don’t know if that’s how they were originally done by the factory,
#3 Re: Headlamp drain holes in bonnet underpanel
Posted: Sat Jul 17, 2021 5:45 pm
by Robsan
If you look at picture 6 on ebay advert. These are the holes I think Geoff is referring ?
https://www.ebay.co.uk/itm/174825365857 ... SwYKZg4Eq4
hope this helps
#4 Re: Headlamp drain holes in bonnet underpanel
Posted: Sun Jul 18, 2021 9:30 am
by johnetype
I don't believe that as they left the factory that the sugar scoops drain pipes came out of any holes in the bonnet underpanel area. On my car there was just a short length of hose connected to the sugar scoop drain outlet that directed the water into the under panel area and the water was left to find it's way out through the holes Robsan refers to, contributing to rusting out my under panel on it's way
When I rebuilt the car I used longer hoses to lead the water out through the holes in the way Geoff has described (- the "P" clips)
#5 Re: Headlamp drain holes in bonnet underpanel
Posted: Sun Jul 18, 2021 10:50 am
by Tonyminett
Thank you everyone. As usual British Leyland had not thought through the problem of drainage. I am going to make a tidy bulkhead fitting in the under panel to lead the water out. Non standard but will not be visible. Under panels cost 2 grand I see!!!!
