#1 indicator bulbs on the dash
Posted: Sat Oct 02, 2021 8:58 am
by Ronald Littlewood
Hi I have tried replacing the dash bulbs with led,s but they didnt work , There are 2 flying leads that take leds & the flash in time with the indicators , perhaps the PO has tried this before?
Also the charging system will not work with an led bulb in the ignition lamp holder ?
Quite strange. any ideas ? TIA
#2 Re: indicator bulbs on the dash
Posted: Sat Oct 02, 2021 9:02 am
Yes charging wont work as not enough current through led to exite the alternator field.....probably same with indicators..you need to do a bit of resesrch to use led replacements....Steve
#3 Re: indicator bulbs on the dash
Posted: Sat Oct 02, 2021 9:10 am
Hi what about fitting resistors? TIA Ron
#4 Re: indicator bulbs on the dash
Posted: Sat Oct 02, 2021 11:30 am
by MarekH
Dear Ronald,
this is quite normal and expected behaviour. It is well documented, both on this website and all over the interweb. I suggest you simply continue using the original filament bulbs for these two applications.
