What colour should the inside of the 'mouth' be?
Caledonian
Topic author - Posts: 2
#1 What colour should the inside of the 'mouth' be?
Having recently acquired a Signal Red 1970 Series 2 FHC 4.2, I'm in the process of carrying out some 'improvements' to it. The bodywork is generally in very good shape, although the previous owner has used (brushpainted) red Hammerite smooth paint copiously to protect various hidden areas of the bodywork, which is a surprisingly good match for the car's body colour. One such area is the 'mouth' of the car, which houses the two scoops which feed the heater and the air cleaner, and makes the opening look quite 'busy' with metalwork, baffles, etc. I've studied various pictures of E-types and on some, they have the area in body colour, whereas in others, aft of the lips of the opening, they appear to be blacked out. I'm minded to spray the area inside the mouth in satin black to conceal the gubbins behind the chrome bumper bar. Is there a definitive way this area should be finished however?
Ian C.
1970 red S2 FHC
1970 red S2 FHC
#2 Re: What colour should the inside of the 'mouth' be?
I'm not sure Ian, but mine is body colour, and most I've seen are like that.
SimonBrown
#3 Re: What colour should the inside of the 'mouth' be?
Hi Ian, I believe these would have originally been body colour
Simon Brown
1969 E Type Series 2 OTS
2013 F Type V6 Convertible
1975 Honda 400 Four
1975 Honda 400 Four
#4 Re: What colour should the inside of the 'mouth' be?
Ian, welcome to the forum, the best place for all things E Type.
Is it possible some of the photos you’ve seen just look dark inside the mouth area due to shadows and hence look black? Mine is body colour.
Happy motoring
Happy motoring
#5 Re: What colour should the inside of the 'mouth' be?
Hi Ian...At the factory an almost fully assembled bonnet was painted body colour inside and out....Steve https://newhillgarage.com/2021/01/18/19 ... ttom-side/
Caledonian
#6 Re: What colour should the inside of the 'mouth' be?
Thanks for all the responses, guys - very helpful. Body colour it is then!
Ian C.
1970 red S2 FHC
1970 red S2 FHC
AussieEtype
#7 Re: What colour should the inside of the 'mouth' be?
The inside of my mouth is black but then it is a black car
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
#8 Re: What colour should the inside of the 'mouth' be?
Not gingivitis is it?
