Hi guys
Does anyone know where I can get the square clips that hold the relays etc to the front frame. I can’t find them on the usual suspects websites and as you can see the ones on my old frame are rough.
Thanks, Colin.
Frame Clips
Topic author - Posts: 178
#2 Re: Frame Clips
Barratt’s do sell them, if you can’t find them in the catalogue give SNGB a call
#3 Re: Frame Clips
Thanks Geoff will do.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#4 Re: Frame Clips
Still struggling with these. Spoke to Barratts but nobody there seems to know what the part is. Does anybody possibly have a part number, or if not could someone please send a pic of the brackets in situ that I can send on to them?
Many thanks, Colin.
Many thanks, Colin.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#5 Re: Frame Clips
There are different shapes but the one in your photo is BD20426. Others are BD20049 depending on application. They are used for mounting the mudguards and seals along with the relays:
https://www.sngbarratt.com/English/#/uk ... Down=false
S1 OTS OSB; S1 FHC ODB
#6 Re: Frame Clips
Hi David, I did get some 00249’s which I found myself. They are black (which I guess I can live with) but they are slightly oversized to my originals and I didn’t think they would pull down. I’ll give them a try. Thanks for your help.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
#7 Re: Frame Clips
Just updated the post with S2 part numbers. The clips were always black as far as I know. Shrink fit plastic over the aluminium. There are only two types depending on which part of the frame they are attached to - one is square other is rectangular.
#8 Re: Frame Clips
Brilliant, that’s a great help. Thanks David.
Colin
Series 2 OTS, 280SL
Series 2 OTS, 280SL
