#1 Servo Reservoir / Heater Box
Posted: Wed Jul 13, 2022 12:25 pm
by colinevans
Hi Guys
A couple of quick questions as I have lost some of my pucs taken during the stripdown. Can anyone send me a good pic showing where the reservoir for the servo clamps to on the near side? Also what are the 3 lugs for that come off the bottom of the heater assembly for (see pic)?.
Cheers, Colin.
#2 Re: Servo Reservoir / Heater Box
Posted: Thu Jul 14, 2022 9:31 am
by Monkeyfinger
Colin, attached are some pics from my car - not sure what you need to see for the servo but hopefully these will help. Your heater motor doesn't look original, but my original has three similar lugs. I happen to have a cable routed through one lug, but I doubt they have any real purpose on an E type and maybe it was a standard motor that Jaguar used?
#3 Re: Servo Reservoir / Heater Box
Posted: Thu Jul 14, 2022 9:53 am
by colinevans
Hi Richard, thanks for that, it’s what I guessed on the heater. On the servo, what I could really do with a pic of is where the fluid reservoir is mounted. I’m not sure if it’s on the mudshield somewhere, an image would definitely help here.
Many thanks, Colin.
#4 Re: Servo Reservoir / Heater Box
Posted: Thu Jul 14, 2022 10:09 am
by Monkeyfinger
Ah, that's an easy one...there's a bracket between washer bottle and the heater box.
Also - since you also have a roadster, have you seen my post this morning ? If you are able to check a dimension for me, it would be a big help...understand if that may not be possible for you right now.
#5 Re: Servo Reservoir / Heater Box
Posted: Thu Jul 14, 2022 10:27 am
by colinevans
Thanks Richard, so that bracket screws to the bulkhead plate?
I’ll try and source one from one of the usuals.
#6 Re: Servo Reservoir / Heater Box
Posted: Thu Jul 14, 2022 10:35 am
by Monkeyfinger
Looks like the bulkhead blanking plate has an upstand welded to it.
#7 Re: Servo Reservoir / Heater Box
Posted: Thu Jul 14, 2022 10:38 am
by colinevans
Thanks, that’s helpful Richard.
