My car is leaking red fluid onto my garage floor but I can't work out exactly where it's coming from!
Any idea's?
Leaking automatic gearbox fluid?
2timcarman
Topic author - Posts: 4
#2 Re: Leaking automatic gearbox fluid?
Put cardboard underneath to help identify where it’s coming from then clean up the area above and narrow down the search.
2timcarman
#3 Re: Leaking automatic gearbox fluid?
Thanks Geoff.
I cleaned things up a bit and discovered that the automatic gearbox sump gasket was leaking. |
I have now tightened the sump bolts up slightly more and will be ordering a new cork gasket as the present one looks as though it could do with replacing.
