#1 Speedo and taqcho refurb
Posted: Tue Aug 16, 2022 4:09 pm
by sulzeruk
Hi all, who is the best for refurbing my speedo and tacho from my Series 2? I presume the tacho will need converted for electonic ignition as well Are Speedy Cables any good?
Alasdair
#2 Re: Speedo and taqcho refurb
Posted: Tue Aug 16, 2022 4:20 pm
Yes speedy cables are very good.....as is Speedograph Richfield http://www.speedograph-richfield.com/
#3 Re: Speedo and taqcho refurb
Posted: Mon Oct 17, 2022 8:34 pm
by TheMadBadger
I’ve used the Spiyda kit in the tachometer of both of my S2 cars. It is fairly easy to do and works very well.
#4 Re: Speedo and taqcho refurb
Posted: Tue Oct 18, 2022 5:52 pm
by tim wood
+1 for the Spiyda kit
#5 Re: Speedo and taqcho refurb
Posted: Fri Oct 21, 2022 10:01 am
by JerryL770
+ another for the Spiyda kit though I've had quite some difficulty with calibration. Not the fault of the Spiyda converter I hasten to add.
My problem showed in that in the car, I never got above about 2k rpm. Calibrated using 100, 200, 300Hz sound files OK. Restored to the car and soon after, not giving correct rpm's again, always low.
Chris at Spiyda advised on moving the brass weight on the rotor and this got me there. I suspect it may be moving due to car vibration. If it does again, I'll have to recalibrate and stick the weight with a tiny application of cyano glue. Not too much or it will affect the calibration!
