#1 Changing contact breaker points
Posted: Tue May 16, 2023 9:44 pm
by Piscator
Today I changed points and condenser. Every time I do this, I worry that I will drop a screw down the inside of the distributor.
What do forum members do to reduce this risk?
1. Use a magnet.
2. Cover gaps with a cloth
3. Use thick grease on the screwdriver
4. Fit electronic ignition
5. Any other suggestions?
I used a combination of method 2 (the cloth) and method 3 (the grease), but I still wasn't totally confident....
Many thanks in advance for your advice.
#2 Re: Changing contact breaker points
Posted: Tue May 16, 2023 10:09 pm
by DWW
Electronic here makes it all pointless :bigrin:
#3 Re: Changing contact breaker points
Posted: Wed May 17, 2023 7:31 am
Note the rotor arm position in the dizzy....slacken the dizzy clamp nut.....pull out the dizzy.....then take it to the bench to fit the points...or by the side of the road....refit..easy.....Steve
#4 Re: Changing contact breaker points
Posted: Wed May 17, 2023 8:40 am
by Piscator
Brilliant, simple, easy when you know how. I'll do it that way next time.
Many thanks, Steve
