I gather this is a common problem but cant find any earlier posts.
Has anyone come up with a solution to prevent water lying in the circular recess in the top of the Air Filter Cannister (C26295). The groove is there to allow the three over-centre catches to grab the lid tightly.
However the groove always holds water when the car is washed or when driven in rain. Currently I extract the water slowly with a chamois - even then it leaves a damp surface and surface rust eventually forms.
I dont think a small drain hole is a solution? The water would then collect in the bottom of the cannister.
Contemplating a large O ring to fill the grove, but this would interfere with three catches.
What is everyone else doing?
