#1 Reversing light wiring FHC series 2
Posted: Wed Jul 17, 2024 3:00 pm
by Beechbum
Hi . I have a series 2 FHC which has had the reversing lights removed and the holes for the wiring blanked off. Could anyone please tell me how the wiring to the rear for them is routed (left or right of the car) and what I have to remove in the boot to get to them (it). I want to see if the switch is still wired and don't fancy taking the tunnel out. Thanks in advance. Steve
#2 Re: Reversing light wiring FHC series 2
Posted: Wed Jul 17, 2024 5:41 pm
by MSM
Iām pretty sure the wiring comes up the LHS of the car. Remove the spare wheel cover and the wiring is generally between the rear lights. The holes for the wires to the reversing lights should be in the flat bit just before the curve of the floor up to the bumper.
#3 Re: Reversing light wiring FHC series 2
Posted: Wed Jul 17, 2024 7:48 pm
by Beechbum
Many thanks Mike. I'll have a look tomorrow
#4 Re: Reversing light wiring FHC series 2
Posted: Wed Jul 17, 2024 9:21 pm
by DWW
I thought the series 2 had a pair of reversing lights left and right or is it just on later ones?
#5 Re: Reversing light wiring FHC series 2
Posted: Fri Jul 19, 2024 8:20 pm
by Beechbum
Yes they should but mine have been removed. Now I've found the wire they can be replaced.
#6 Re: Reversing light wiring FHC series 2
Posted: Sat Jul 20, 2024 4:51 pm
by JerryL770
Beechbum wrote: āFri Jul 19, 2024 8:20 pm
Get LED ones from Marek and fit them in your rear light lenses in place of the rectangular reflectors which can easily be prised out. Much more effective than the original reverse lights - unless you crave authenticity that is.
- Reverse lights.JPG (74.19 KiB) Viewed 64747 times
