Hazard flashers
Geoffrey Spetch
Topic author - Posts: 3
#1 Hazard flashers
S2 1971 E has separate flasher can, where is it located? The wiring diagram shows the hazard switch terminals numbered 1-6,in a certain order, on my switch the numbers are in different positions shown on the back of the switch. Which should I follow the actual position of the terminals on the switch or connect the wire colours to the numbers on the switch. My hazards are obviously not working at present, blinkers are. Thanks Geoff
#2 Re: Hazard flashers
Have you got a rectangular flasher on the firewall behind the centre instrument console?
Geoffrey Spetch
#3 Re: Hazard flashers
The standard round blinker flasher can is in the centre of the back of the dash, next to the rectangular relay 33285B. Geoff
Geoffrey Spetch
#4 Re: Hazard flashers
Hazard flasher can on LHS dash behind glovebox . Now to solve the hazard switch problem???
