#1 Hazard flashers
Posted: Thu Jul 18, 2024 12:46 am
by Geoffrey Spetch
S2 1971 E has separate flasher can, where is it located? The wiring diagram shows the hazard switch terminals numbered 1-6,in a certain order, on my switch the numbers are in different positions shown on the back of the switch. Which should I follow the actual position of the terminals on the switch or connect the wire colours to the numbers on the switch. My hazards are obviously not working at present, blinkers are. Thanks Geoff
#2 Re: Hazard flashers
Posted: Thu Jul 18, 2024 12:50 am
Have you got a rectangular flasher on the firewall behind the centre instrument console?
#3 Re: Hazard flashers
Posted: Thu Jul 18, 2024 5:42 am
by Geoffrey Spetch
The standard round blinker flasher can is in the centre of the back of the dash, next to the rectangular relay 33285B. Geoff
#4 Re: Hazard flashers
Posted: Fri Jul 19, 2024 4:31 am
by Geoffrey Spetch
Hazard flasher can on LHS dash behind glovebox . Now to solve the hazard switch problem???
