Glove Box Locked
Czwbkx
#1 Glove Box Locked
Post by Czwbkx » Mon Jan 20, 2025 4:20 pm
The previous owner misplaced the glove box key for my '69 FHC. Does anyone know of a minimally destructive way to open the locked glove box?
Thank you.
Cz
'69 XKE Series II FHC
MarekH
#2 Re: Glove Box Locked
Post by MarekH » Mon Jan 20, 2025 7:57 pm
Take the front half of the dash off and dismantle it from behind.
#3 Re: Glove Box Locked
Post by mgcjag » Mon Jan 20, 2025 9:03 pm
They are quite simple locks....a thin blade inserted and giggled about and you could get lucky....or a locksmith could probably pick it....Steve
Czwbkx
#4 Re: Glove Box Locked
Post by Czwbkx » Tue Jan 21, 2025 12:52 am
Thank you. I used a combination of the two answers above. After removing the outer trim ring the lock mechanism was just loose enough to allow use of a thin blade to depress the lock tang. I'll order a new cylinder assembly and key now.
Thanks again for your help.
Cz
tim wood
#5 Re: Glove Box Locked
Post by tim wood » Tue Jan 21, 2025 10:16 am
Take the lock apart and the key number should be marked on it.
#6 Re: Glove Box Locked
Post by Gfhug » Tue Jan 21, 2025 12:44 pm
It is not difficult to have all locks keyed alike. Either ask a locksmith or find a few old locks you can take apart and swap the leaves about.
