series 2 Alternator woes
Keith in Norfolk
#1 series 2 Alternator woes
Post by Keith in Norfolk » Thu Feb 06, 2025 2:07 pm
Well chaps my original Lucas Alternator has finely bitten the dust after many rebuilds.
The garage has offered me a replacement which will fit however this one has a built in regulator ( modern upgrade ? ) now i am no auto electrician but i assume this will by pass the regulator box and may need a rewire is this correct ? any help suggestions or wiring diagrams would be most welcome.
tim wood
#2 Re: series 2 Alternator woes
Post by tim wood » Thu Feb 06, 2025 8:44 pm
Hotrod
#3 Re: series 2 Alternator woes
Post by Hotrod » Fri Feb 07, 2025 12:20 pm
Hi Keith,
It’s a real nuisance I know. Happened to me in France last year. Martin Robey also sell one on their site which has the new wiring diagram as a download. I got mine from Winspeed and used the Martin Robey diagram to do the re wire. Not a very difficult job even for someone with my lack of electrics prowess!
Good luck.
Rod Evans
1969 S2 DHC LHD
Keith in Norfolk
#4 Re: series 2 Alternator woes
Post by Keith in Norfolk » Fri Feb 07, 2025 1:41 pm
Thank you for your feed back , most helpful .
Looks like Martin Robey is the way to go , the wiring diagram is brilliant and helps a lot. :thumbsup:
Jack the lad
#5 Re: series 2 Alternator woes
Post by Jack the lad » Fri Feb 07, 2025 4:57 pm
Are you certain that it is your alternator that has failed? The 4TR regulator or the wiring would be my first port of call and would be far cheaper than a replacement unit.
Keith in Norfolk
#6 Re: series 2 Alternator woes
Post by Keith in Norfolk » Sat Feb 08, 2025 3:15 pm
The 4TR was replaced 2 years ago , i keep a record of everything done or replaced on the car.
I have taken off the Alternator and pulled it apart and found one of the brushes had some how moved back from the contact disc and not making any contact , i am hoping this is the problem , will keep you posted.
Jack the lad
#7 Re: series 2 Alternator woes
Post by Jack the lad » Mon Feb 10, 2025 5:25 pm
Hi Keith, the usual cause of brush trouble (other than wear) is too much end-float on the armature of the alternator, new bearings are very cheap but please buy quality ones for just a couple of pounds more. If your slip ring is worn or damaged they are easily replaced too, I think I have a new one somewhere if you get stuck. The original 11AC is a very sturdy unit and well worth keeping on your car, I do have one for re-conning if you need it, cheers John.
