Air cleaner base and trumpets connection to carburetors
BlackJag
#1 Air cleaner base and trumpets connection to carburetors
Post by BlackJag » Fri Jul 11, 2025 3:30 am
There are four holes on each of the three SU carburetors on my Series II OTS.
The bottom two holes take the hex screws, lock washers and nuts to connect the air cleaner's base and trumpets part to the carburetors.
What, if anything, goes into the other two holes indicated with red arrows on my photo?
If nothing goes into these holes, what is their purpose other than letting in unfiltered air into the carburetors?
Paul 1969 Series II OTS E-Type 1R7218
#2 Re: Air cleaner base and trumpets connection to carburetors
Post by mgcjag » Fri Jul 11, 2025 8:52 am
Dashpot chamber vents......Steve
BlackJag
#3 Re: Air cleaner base and trumpets connection to carburetors
Post by BlackJag » Fri Jul 11, 2025 3:19 pm
Thanks Steve. I didn't have a clue, but totally understand now.
#4 Re: Air cleaner base and trumpets connection to carburetors
Post by bitsobrits » Fri Jul 11, 2025 3:28 pm
That they are open to atmosphere is why one should remove the dashpots and thoroughly clean them and the air pistons at least every other year. If the car is driven frequently then once a year is not too often.
