Hi for some reason my left hand cooling fan has stopped working , ( The right hand one is fine )
is this a motor problem or perhaps the relay needs replacing ? i have checked all the wiring and connections and all seems fine .
Cooling fan not working
Keith in Norfolk
Topic author - Posts: 52
#2 Re: Cooling fan not working
Best way to test is by feeding 12V to the suspected fan....
#3 Re: Cooling fan not working
Before consigning the failed fan motor to the bin and forking out a significant sum for a replacement, remove the rear cover and check the piece of cardboard - yes I kid not - that holds the tension springs together that keep the brushes on the commutator - or not.
1969 Series 2 FHC
1969 Series 2 FHC
#4 Re: Cooling fan not working
Not cardboard, probably Nomex card, which is a high dielectric strength insulating material.
Would you really believe that a motor manufacturer would use a piece of cardboard in a motor? If it really was cardboard then some bodge monger has been there before you.
#5 Re: Cooling fan not working
No one has been in there before, I've owned the car for too long. Whatever it is it is certainly not high quality and over the years the ends of the springs pull through it and let go.
Producing a plastic based replacement is a great 3D printing opportunity.
1969 Series 2 FHC
1969 Series 2 FHC
#6 Re: Cooling fan not working
Maybe, but watch the tracking index of the material you use. It isn't something commonly quoted in filament properties. Also, the layered nature of the print may provide an easy tracking path through the part.
