#1 Strange One For You!!
Posted: Thu May 21, 2026 3:08 pm
I have a problem with the radiator cooling fans, When you open and close the bonnet it stops the fans and eventually blows the 40amp fuse that I have wired direct to the battery. I have a temporary switch wired up to the otter switch, when pressed it simulates the operation of the otter switch. If you leave the bonnet up the fans run continuously, if you have a smaller fuse in place it blows as soon as the catch touches. With the 40amp fuse it turns the fans off a couple of times and then eventually blows the fuse. The fans are new along with the relay and the otter switch.Has anyone ever experienced this?
