Ignition Key Barrel Removal
Stevegtx
#1 Ignition Key Barrel Removal
Post by Stevegtx » Wed Jun 24, 2026 5:53 am
Can anyone tell me how to remove the key barrel from a 1969 Series 2 E type?
(I placed my original post with the wrong subject heading).
Dr Google tells me there is a small hole in the casing and if you insert a pin, with the key turned to Aux, the lock pulls out but I can't see a hole.
#2 Re: Ignition Key Barrel Removal
Post by mgcjag » Wed Jun 24, 2026 6:07 am
Look at the link I posted in your other thread.....Steve ps on a Britex you can drill out the pin to release the key switch and re tap for a grub screw to re assemble
