Engine Identification
Smeg999
#1 Engine Identification
Post by Smeg999 » Tue Oct 04, 2011 8:34 pm
My engine is non-standard and I have been trying to confirm the model (XJ6?) and year; the number is 8L 1809XX. I am told that is one digit too many, but it is definitely 6 digits after the 8L.
I haven't yet found a detailed cross reference, so I would appreciate any info you may have.
Ian
70 E-Type Jaguar
Non illegitimus carborundum
Post by christopher storey » Tue Oct 04, 2011 10:34 pm
This is from an S3 XJ6. You can confirm it positively by looking at the external surfaces of the block by each core plug : an S3 motor has ribbing running vertically either side of the core plug . I doubt that there are too many digits : the last is probably an S H or L denoting standard high or low compression ratio
Post by PeterCrespin » Wed Oct 05, 2011 9:17 am
christopher storey wrote:This is from an S3 XJ6. You can confirm it positively by looking at the external surfaces of the block by each core plug : an S3 motor has ribbing running vertically either side of the core plug . I doubt that there are too many digits : the last is probably an S H or L denoting standard high or low compression ratio
FWIW the late Series 2 blocks had this vertical ribbing too AFAIK, but they also used left side cam feed whereas the S3 went to right side and spin-on filter block. Not that this kind of thing can't be swapped around, including blocks, but still. There's an engine-number decoder somewhere on Jag-Lovers I think
